Search for rebar tensile test 2,800kN
I am currently looking for a material testing facility of building material products that has the capability of conducting destructive tensile tests on reinforcing bar to ASTM A615 /ASTM A370 standard.
The testing machine will need to be of particularly high calibre as the breaking strain of the bar is 2800kN. The bar is a high grade 63.5mm bar.
I would be most grateful if anyone could direct me to such an institute.
Cheers Big Bars.
Cheers Big Bars.
RE: Search for rebar tensile test 2,800kN
The Testing Buyers Guide published in the August 2003 issue of Advanced Materials & Processes presents a list of Testing Services offering Mechanical Testing.
By inquiring at the advertisers you can probably find what you need. See www.asminternational.org/tgb
http://www.welding-advisers.com/
600,000 lb. capacity , can grip up to 3.5 inches
The capacity is somewhat less than what you require.
Please contact me at lvitkus@twininglabs.com if we can help out.
http://www.tam.uiuc.edu/directory/services/testing/test...
While located at a University, the facility is available for testing of commercial products. While I was a student in the building I witnessed the machine in action several times, and it was always quite impressive. Might be a bit overkill for your needs, but it should meet them.
Jick
