MsgBox in VB6
MsgBox in VB6
MsgBox in VB6
I would like to know if it's possible to take off the alert sound that a msgbox makes in VB???
Best regards, Carlos Cardoso
RE: MsgBox in VB6
Not without various hacks, as far as I know - it's a user setting. Using your own (custom) dialog box is the cleanest way around it.
RE: MsgBox in VB6
If you want you could use this code below do it, however the message box will be a Question message box.  The Question message box will not make the alert sound.
Heres the code:
prompt$ = "Put Message here"
reply = MsgBox(prompt$, vbQuestion, "Put title here")
Justin Dean,PE
RE: MsgBox in VB6
The alert sound is not a vb option, is a windows option that is on the control panel and sounds and multimedia, could be the question sound "chord.wav" that logically is on the registry
There's a key on the registry where you can find out about the sounds
HKEY_CURRENT_USER\Schemes\Apps\.Default
And in there most likely is the following the one that controls that sound:
HKEY_CURRENT_USER\Schemes\Apps\.Default\SystemQuestion\.Current
you can modify it on and off every time that you use your application. Well, is just and idea.
