how to handle 1700 lbs ?
I am designing an assembly line for heavy containers with a lot of components attached inside and outside. Total weight is about 1700 lbs and the footprint is square 45 inch.
The assembly should be moved between 4 assembly stations at about every 3-4 hrs. What would be the cheaper way to do it? I am thinking of pneumatic platforms or platforms on balls and floor covered by steel sheet, etc.
RE: how to handle 1700 lbs ?
Cheers
Greg Locock
Ray Reynolds
"There is no reason anyone would want a computer in their home."
Ken Olson, president, chairman and founder of Digital Equipment Corp., 1977
Have you read FAQ731-376 to make the best use of Eng-Tips Forums?
- quality of floor you would like to have and to maintain in time
- can you accept rails to be present, and should they be flush with floor level?
- effort you require to have the load displaced: mechanical or hand driven?
- if it is mechanical, can you accept chains or cables to be over the floor or would you require them to be below the floor level?
- how is the load transported to its first location and how is it evacuated from the last one?
The cheapest way is undoubtedly elastomeric or pneumatic wheels on flat floor, the limit of this method is that the displacement by hand of that load will require some effort. Air pads are more costly, require an air supply, but can be very easily moved by hand (see www.levitans.com ). Can't personally see the advantages of ball rollers, as a much stiffer and perfectly flat soil would be required for them to behave correctly.
prex
http://www.xcalcs.com
Online tools for structural design
Working height for assemblers;
Final packing/packaging requirements.
I've been through this twice, once for appliances and once on semi trailer bodies.
If you use a dolly of some sort, wheels or air pads, somehow they must be returned to the front of the line and often stored. Roller track or overhead lifts avoid this.
The working height for assemblers may be somewhat higher than available with air pads. Dollies at the correct height will take up more space and be heavier.
Do these units get shipped on pallets? Are they boxed, stretch wrapped, or enclosed? Can they move down the line on the final shipping base? Do the assemblers need access to all sides or can they work from one side or the other? What kind and amount of feeder lines are needed/used?
Could you use sections of powered roller track?
These are just a few of the issues we encountered in addition to those posted by others here.
Good luck.
Griffy
