steam jacketed vessels
Our company manufactures steam jacketed kettles in accordance with ASME Section VIII, Division 1. Is there any computer program which include jackets in accordance with Appendix 9 and gives credit for a nozzle penetration through the jacket which would act as a stay thus decreasing the required inner and outer shell thickness?
RE: steam jacketed vessels
If you use nozzles as stays (you may) but you have to put a lot of them to make them have value.
I do not know about a comp. progr./or if exist.
ER
Which type of jacket are you considering ? Half-pipe ? Dimpled ?
"Codecalc" considers "half-pipe jackets" in the design of pressure vessels as per ASME VIII ( Appendix EE)
www.chempute.com/codecalc.htm
The COADE product,"Codecalc" performs a similar evaluation
www.coade.com/ccarticles/pcc_ad_2.htm
Start with these two and ask the developers....Please report back to us, as a common courtesy, on what you have learned.
My opinion only.....
MJC
"There comes a time in the affairs of man when he must take the bull by the tail and face the situation." W.C. Fields
