Need a Lisp that will correctly rotate attribute text in blocks
I am having trouble w/attribute text being flipped or upside-down when blocks are inserted in an left or down orientation.
I can email you an example..
Thanks!
-Chane
Thanks!
-Chane
RE: Need a Lisp that will correctly rotate attribute text in blocks
which AC-version? Express Tools? Which textfont?
You can mail the *.dwg... ( look at nmy profile )
Lothar
Press a few times ENTER untill you have to select an attribute.
Select neccesary attributes.
Then you can change te angle off the attributes you have selected.
mvg
HMO
http://www.dotsoft.com/freestuff.htm
And download Terry Dotson's routine:
INSROT.LSP Which inserts rotated blocks with the attributes maintained horizontal.
- Tracy
