Pro/Con using PLC for analog input?
My company does not use our S7 300 series PLC for analog inputs.
Instead we use these:
http://bellsouthpwp.net/h/a/haygood33/karl.htm]
http://www.dr-staiger-mohilo.de/e_kraft-weg_DMFPV3.html
I ask the engineers why not let the PLC do the work??
They say too much programming....
What are the benefits of using these instead of the PLC?
Thanks!!
Thanks!!
RE: Pro/Con using PLC for analog input?
Datalogging in particular can require a degree of programming that may have shaped your engineering decision.
Does this help?
