Assembly Performance
Hi
Can any one explain how to increase performance for the assembly ?.I have a top level assembly & few say 10 sub assemblies. In tools->option->performance ive enabled the 'Automatically load components lightweight' & resolve lightweight component to 'ALWAYS'. Then when i opened the top level assembly I found that all the sub-assemblies are in resolved state. But the parts in sub-assembly are still in lightweight..Also If all my top level & sub-assemblies are in lightweight, iam not able to select the sub-assemblies planes for an new sub-assembly for mating.All i see is the part doc & not any assembly planes in lightweight sub-assembly component.
slee
RE: Assembly Performance
What version of SolidWorks and what service pack are you running?
What operating sytem are you using?
What video card and video card driver are you using?
What is the speed and make of your system processor and how much memory are you working with?
Ray Reynolds
"There is no reason anyone would want a computer in their home."
Ken Olson, president, chairman and founder of Digital Equipment Corp., 1977
Have you read FAQ731-376 to make the best use of Eng-Tips Forums?
Hi MadMango
Iam using SW2004 ServicePack1
O/S- Win 2000 pro
Matrox G450 32 MB
PIII 1ghz dual processor with 512 MB ram
It seems to me that you are pushing the performance envelope with the computer system you have.  I'm sure it was a nice system 2 years ago.  Try to get some more memory, this will increase performance (512mb just won't cut it anymore).
Ensure that you are running the 5.82.018 drivers for your Matrox card.
Try to log into SolidWorks website, and look at Best Practices in the Implementation Guide.  Some things to look at are:
In System Options>Display/Selection-
Part/Assembly Tangent Edge Display= Removed
Edges Displayed in Shaded Mode= No Edges
In System Options>Performance-
Enable Automatically load parts Lightweight (you said you have this one).
In System Options>Large Assembly Mode-
Change your large assembly threshold to some lower value.
Enble Automatically load parts Lightweight (You might have missed this one).
Disable Hide all planes, axes, sketches, curves, annotations, etc (This might be causing your problem of not seeing planes in the assembly for mating).
Ray Reynolds
If you click the help on the large assembly mode it will tell you what options to choose for optimal Performance.
How large of an assembly are you working with? 10 sub-assemlbies doesn't say much because we don't know how many parts are in those subs.
I agree with MadMango, your probably maxing out everything about your system. Watch your Task manager to see how much RAM your using. I bet your using all the memory. I wouldn't recommend anything under 1 gig with SW04 and working with large assembly.
Clean your Temps out.
Get the Drivers SW recommends for your Video card. Or get a new card.
Work locally.
Check HDD space.
Don't use those little crappy programs that do little stupid things - Example: Weather bug - Shut that stuff off.
Scott Baugh, CSWP
http://www.3dvisiontech.com
http://www.scottjbaugh.com
FAQ731-376
Your dual processors are not doing anything for you with SW.  Check with recent threads on the subject for more detail.
Next.  Correct me if I am wrong, Scott, but if you load anything lightweight, all you really get is topographical data for display plus mate data, etc. So if you want to interogate a part of assembly to feature level )select a plane, etc.) you have to resolve that part.
Be naughty - save Santa a trip.
Hi madmango
ive missed out some thing .What ever said regarding in the option ive already set it
apart from the above ive enabled resolve lightweight component to 'ALWAYS'
when ever i open an assembly the SW first it open in lightweight mode & then it should solve the lightweight to resolved as ive made the resolve lightweight component to 'ALWAYS'.
All i need is to insert an assembly in a top level assembly which is opened in lightweight with mates respect to the planes in the subassembly.but the planes in subassembly dosent show the planes as all my subassemblies are also in lightweight. IS there any other option to insert an assembly w.r.t subassembly planes without resolving the sub-assembly.
Yes, if you want to make a change to a part you will need to resolve it. But if your looking to regain some speed of the assembly. Then I would load it lightweight and only resolve the parts on a needed basis.
Scott Baugh, CSWP
FAQ731-376
Bingo, Scott - that's what I meant really. I should have been more specific.  Need basis for individual parts only for resolving!!!
Never tried this, but do you get the RAM back if you reload them lightwiehgt once you have finished messing with them?
hi slee,
i don't know this will solve ur problem or not , but try this in ASSEMBLY ONLY...
have u enabled tools-options-performance- verification on rebuild?  if u enabled ,  deselect it.
now  check ur assm performance.
thanks,
regards,
Murugan.S
Design Engineer,
GlobalSoft Pvt Ltd,
New Delhi, INDIA.
murugan_subham@yahoo.com
HI guy thanks a lot for the info .this really helped me a lot.
Also one more thing is that ive have a top level assembly & several sub assemblies init. my first sub assembly has only planes & 3Dsketches .Now all my subassemblies are in lightweight.Now i wanna use these planes in sub assembly which is in lightweight to be used for adding mates to other assemblies without resolving it .
Senthil Kumar.E (B.E Mechanical)
senthile@geometricsoftware.com
