QW 200.4 (a)
QW 200.4 (a)
QW 200.4 (a)
I have a questoin for QW200.4(a) of ASME SecIX where we read "one or more processes  or precedures may be deleted from a qualified combination procedure".
My WPS:
Base metal thickness:14 mm
process:GTAW
My PQR:
Base metal thickness(Same P-Number and G-Number):20mm
process:GTAW + SMAW
Deposite weld metal thickness:8mm(root and hot pass)
* Other essensial,nonessensial and supplementary variables are same.
*Notch-Toughness test is required.
Now I want to know this PQR support my WPS or not. If answre is "No" why?
H.Mirhosseini
RE: QW 200.4 (a)
No, see QW 403.6 for minimum qualified base metal thickness.
Thanks and regards
Sayee Prasad R
Ph: 0097143968906
Mob: 00971507682668
email: sayee_prasad@yahoo.com
The black holes of nature are the most perfect macroscopic objects there are in the universe: the only elements in their construction are our concepts of space and time.
RE: QW 200.4 (a)
Thanks a lot!
Could you tell me about following situation:
1- The same WPS and PQR (if Notch-Toughness test is NOT required).
2-
WPS:
Base metal thickness:16 mm
process:GTAW
PQR:
Base metal thickness(Same P-Number and G-Number):25mm
process:GTAW + SMAW
Deposite weld metal thickness:9 mm(root and hot pass)
**Notch-Toughness test is required
**Other essensial,nonessensial and supplementary variables are same.
Please notice that these promblems are not REAL.
I want to understand the Code(ASME Sec IX) better.It is very good if you bring an example for QW200.4(a)
Thanks again
H.Mirhosseini
RE: QW 200.4 (a)
1- Yes.
2- Yes.
Thanks and regards
Sayee Prasad R
Ph: 0097143968906
Mob: 00971507682668
