User specific drafting frames
Hi people
I´ve set up a CATDrawing with numerous frames in different sizes, now I don´t know how to set it up so I can insert the frames when I´m making a new drawing. Any suggestions?? would really appriciate some help.
Thanx in advance
Thanx in advance
RE: User specific drafting frames
Have you tried this:
In your new CATDrawing select File/Page Setup.
In the Page Setup window select Insert Background View.
In the Insert elements into a sheet window browse to the CATDrawing that you created then pick Insert.
Finally, click OK from the Page Setup window.
Create empty drw files. In edit menu select background,
create your default titlebloks. Leave it in background
mode.Save the file as A0 temp. When u want to create
a new drw, use File->New and select A0 temp.
I made several drw files (A0 to A4). I use F->New Frm,
select which temp u wnt to use, change titleblok text
and save it with a new name. Then change to working view
Edit->Working View create ur drws.
Hope this help.
The page setup worked fine.
