LPDA on PCB I need help
Hi
I have noticed that Winradio have a logperiodic antenna on PCB. http://www.durhamradio.com/winradio-ax-31b-log-periodic-antenna.html
I looks like they feed the antenna from the rear instead from the front as normal.
Does anyone know if there is problem/special design hint to do this ? I need to use this type of feed in an other design.
I am also interested in any (!) designes of log-periodics on PCB. Please.
Sincerely Johan
johan@oboj.net
Sincerely Johan
johan@oboj.net
RE: LPDA on PCB I need help
<nbucska@pcperipherals.com>
