Pack and go non xrefed drawings
I know using before you send out a drawing via e-transmit you need use to use pack-n-go to make sure that the transmittal contains everything needed.
But is there anyway you can link non xrefed files together so that when you pack and go it grabs those files too.
For example:
You have a site layout, and it has armco on it. You have a std. drawing for installing armco. Which isnt shown in the site drawing, but it's mentioned in the notes.
Is there a way to send the drawing and so it'll grab the std. drawings too.
As at the moment I have to search around and zip them alltogether, It would be nice to save time and have it done automatically.
cheers,
For example:
cheers,
RE: Pack and go non xrefed drawings
Interesting. If I find a way, I'll let you know
