Deform SW2004
Deform SW2004
I have a cable that has a braided shield inside. Is there a way to deform this shield around and away from the cable conductors? The shield has an I.D. and O.D.
thank you
thank you
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: Deform SW2004
Be naughty - save Santa a trip.
RE: Deform SW2004
RE: Deform SW2004
In 2004, the feature looks a tad more parametric, but now I'm so used to making parametric curvy stuff with other methods--usually sweeps--that I haven't yet found use for the new feature.
Wouldn't a sweep accomplish what you need?
Jeff Mowry
Industrial Designhaus, LLC
http://www.industrialdesignhaus.com
RE: Deform SW2004
RE: Deform SW2004
I did on a very basic example. I used both methods curve to curve and point. See the config manager for the different types. I had to make them separate bodies.
http://www.scottjbaugh.com/Design_Portfolio/SW%20Models...
I hope that helps.
Scott Baugh, CSWP
http://www.3dvisiontech.com
FAQ731-376
RE: Deform SW2004
If you only want to "open-up" the shielding on your cables (assuming it is like normal coax cable), can't you create a new config of the shielding and cut it back some, then add a revolved feature to simulate the shielding as being pulled away from the conductors?
Ray Reynolds
"There is no reason anyone would want a computer in their home."
Ken Olson, president, chairman and founder of Digital Equipment Corp., 1977
Have you read FAQ731-376 to make the best use of Eng-Tips Forums?
RE: Deform SW2004
MadMango, I know what you are saying, but I needed to model the shielding to look like it has been cut to same length as conductors then twisted to one side of the conductors to get soldered to another pin (case ground).
I have been drawing this on the dwg, but I have a customer that needs it modeled.
thank you
