Hiding units of dimensions.
When I insert dimensions in fraction in the drawing, it automatically gives inch mark(") after the dim values. Does anybody know how I can get rid of " mark, while still displayed in fraction??
RE: Hiding units of dimensions.
u didn't tell which Solidworks Version u r using.
pls follow these steps,
Tools-Options-Document Properties-Units-
here below the Linear Units - Select Decimal Option (instead of Fraction option)
here u can change ur current units types also like mm, cm, inches, feets etc..
i think this will solve ur problem.
thanks,
regards,
Murugan.S
Design Engineer,
GlobalSoft Pvt Ltd,
New Delhi, INDIA.
murugan_subham@yahoo.com
I am using SolidWorks2003.
I wanted keep fractional display without showing inch annotation. Is it even possible? I've heard you can accomplish this by typing something instead of <DIM> under dimension value.
Uka
Unfortunately, though, I cannot help you with removing the inch marks from the text.
I guess I will choose decimal option...
Uka
