Concrete Snow Removal
I have new concrete sidewalks being installed in the Philadelphia area and I know that de-icing salt will damage the concrete, especially newly poured concrete. Sealing the concrete is an option, heating ducts under the concrete is not.
I am curious of others opinions for the removal of snow and ice on concrete surfaces. Please advise. Thank you.
RE: Concrete Snow Removal
1) Snow blower
2) Shovel
3) Spring
Actually, I tell clients to use sand on slippery surfaces rather than salt. People may not like tracking sand into offices and homes, but it really is less damaging than salt on floors. Sand is also enviormentally friendly which is nice too!
If it is all light fluffy stuff, then sand might be OK. But if they get freezing rain, or melted snow freezing at night, the sand will do no good at all. the ice will just build up over the sand giving you nice tan colored ice. Once the ice thickness is greater than the sand particle diameter, you might as well forget the sand was ever there. But salt will keep melting, even if it gets temporarily covered in ice.
Any form of mechanical snow removal will leave a thin layer of snow, which is very prone to melting than freezing. So again, salt is wise.
As for the concrete itself, your best bet is to use a very high quality concrete, say at least 5000 psi. Also, use some fly ash or ground slag to increase the density of the concrete. And make sure you place strick limits on water cement ratio, keep it at most 0.45, preferably .4. And use appropriate entrained air. Basically, follow all the suggestions from ACI 318 chapter 4, and make sure the contractor strictly adheres to the specs. They will always cry about such strict requirements just for sidewalks.
