Welding joints without filler
Does anyone know what to call welding which requires no filler. In german it is called "verschwemmt" but I have been unable to find a translation into english. We put this text on drawings of sheet metal parts where a mortice joint between two st. steel parts is welded after assembly to give a permanent joint. The two parts are literally melted together from one side to give a smooth permanent joint.
Many thanks.
Matt
Many thanks.
Matt
RE: Welding joints without filler
Thanks and regards
Sayee Prasad R
Ph: 0097143968906
Mob: 00971507682668
email: sayee_prasad@yahoo.com
The black holes of nature are the most perfect macroscopic objects there are in the universe: the only elements in their construction are our concepts of space and time.
Matt
