Extract geometry-shaded view
I have a problem with shaded view of an extracted surface of a solid.
While it is in rotate,zoom or pan mode, I am getting a square and rectangle like shade on the screen for few moments after the mouse is being released.
This problem is only with the extracted surfaces.
When the solid is rotated,the shaded views are very sharp and clear.
Any solutions please. Anything with the configuration of default settings?
RE: Extract geometry-shaded view
Visualization Performance (?)
Large model
There is a check box that when you rotate/zoom/pan models, they turn into blocks for faster refresh.
Ben Loosli
CAD/CAM System Analyst
Ingersoll-Rand
as looselib said go to
preferences-->visualisation performance-->large model
in that there is a scroll.make it to minimum.
The scale will be 1-20.Make it to 1 .
U will not get the rectangle like thing ,
Thanx,
Karthikeyan.J
Thanks all of you.
It works..
Wish you all a happy new year.....
