Draft Quality to High Quality
Morning Board.
SolidWorks 2004 SP1.0
I brought an assembly into a drawing and had the lightweight option set as well as the quality set to draft.  After setting components to resovled,  the assembly still plots out in draft quality.
Where do you set the quality after resolving the components?
Todd
RE: Draft Quality to High Quality
In the print dialog box there is a setting to convert draft quality views to high quality.
Rockguy,
Thanks.  I found it right after I posted the thread.
Todd
