Spline problem
Spline problem
When I draw a spline, I pick a number of different points to give the line a curve. This part is normal except the points don't show up and I can't edit the profile of the line. Anybody hear about this one?
RE: Spline problem
But that really doesn't answer your question. Go to Tools\Options\System Options\Sketches\(check mark)"Display Entity points in Part/Assembly Sketches.
You have to be editing the sketch for them to show up.
Scott Baugh, CSWP
http://www.3dvisiontech.com
http://www.scottjbaugh.com
FAQ731-376
