Parallel Compressors operation problems
I’m working for a client who wants to replace a single direct expansion ac system compressor with two compressors both rated for the total system load. However, they want to operate both compressors during peak load conditions. What kind of problems, other than oil return problems, can be expected with parallel operation and how can they be avoided?
RE: Parallel Compressors operation problems
hope this helps.
-pmover
and an equilization line to each compessor that is above the oil to equilize the pressures in both compressors for proper oil level
