Reinforced Concrete Tanks
Does anyone know of any specific codes or reference materials for the design and analysis of circular reinforced concrete tanks? (No prestressing or post tensioning...only rebar)
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: Reinforced Concrete Tanks
Are concrete storage tanks containing liquid required to have a liner, or is it possible to construct them without one? Are there any codes out there that address the specific issue of the requirement for a liner?
Thanks!
As far as specific designs, PCA has a good publication titled "Circular Concrete Tanks Without Prestressing" which gives excellent examples and tables on the design of Circular Tanks. Unfortunately, their publication on rectangular tanks is not so good. The best publication for design of rectangular tanks is the out-of-print "Moments and Reactions for Rectangular Plates" by the United States Bureau of Reclamation.
As far as lining, unless the liquid contains some aggressive chemicals no lining is necessary.
Can you please provide me with that.
EUE
I found a methodology to calculate the moments in the walls,(PCA Rectangular concrete tanks). But the examples are only with cells that have the same size.
Can I use this procedure in tanks with different cells??
Don't forget shears!
