Make components local in an assembly -- e-mail just the assembly
I want to e-mail an assembly to my collegue, but I don't want to e-mail all the sub components. Is there a way I can make the subcomponents local to the assembly so I just can send him the assembled model? He needs to incorporate the assembly into a larger model but doesn't need to dig into any of the sub components.
I guess I could save the assembly as a iges, sat, para etc.
Are there otherways??
Thanks for the tips.
DG
DG
RE: Make components local in an assembly -- e-mail just the assembly
Scott Baugh, CSWP
http://www.3dvisiontech.com
http://www.scottjbaugh.com
FAQ731-376
Can you still use section views??
DG
Best way to test it is to try it out.
Scott Baugh, CSWP
FAQ731-376
I was trying sectioning it while you must have been responding.
I didn't seem to work.
When I saved the assembly as a parasolid and brought that back in it worked fine. It even recreates a part file for each part although the part is a solid and does not retain its features.
DG
I just tested this and it worked fine. See link -http://www.scottjbaugh.com/Section_part.jpg
Scott Baugh, CSWP
FAQ731-376
Thanks again,
DG
