ASME B-31 and Aerospace applications
I’m looking for references and technical information relating to thin wall tubing systems; specifically Aerospace Fluid Delivery Systems. I’ve seen many references to ASME B-31. Before I spend $300 on the specification, can anyone tell me if this specification would shine light on theories that could be applied to thin-wall tubing? Does this specification address analysis techniques for initial sizing? Any advice is greatly appreciated.
-cbreay
Denver, Colorado
-cbreay
Denver, Colorado
RE: ASME B-31 and Aerospace applications
For allowable operating pressures, tubing fittings, etc. see www.swagelok.com for example.
If you use common materials (e.g.SS) then you could get at least the formulae for calculating wall thicknesses, but once again I wonder whether you use the same allowables as the codes, and that's the main point where you need the code to design a piping system.
So once again don't think you'll find the code useful.
The above holds if your tubing is going to fly. If it is part of a ground system, then you should normally design it according to a B31 or similar code.
prex
http://www.xcalcs.com
Online tools for structural design
Happy Holidays!
-cbreay
Below is the site to Aeroquip's design handbook
www.aerospace.eaton.com/pdfs/aeroquip/tube_bend_rule.pd...
