Printing Troubles w/ AutoCAD 2002 LT
After updating my computer to an XP system, and updating to AutoCAD 2002 LT, the plot style table I used previously prints out differently than before. The lines are no longer as thin, the minimum width that my machine will now print is twice as wide as it was previously. Setting the pen width for my Oce 9400 will not vary the width below a certain value, which I know from the past the plotter is capable, but now I cannot get AutoCAD to print the same fine lines in its current setup. I have been wondering if it is a driver issue or perhaps a variable has been changed that I do not know of.
Does anyone have any similar experience or advice?
Daniel
RE: Printing Troubles w/ AutoCAD 2002 LT
I have had this problem with AutoCAD 14 and 2002 on several versions of windows, but in my cases it was always caused by the printer driver (most of the time a driver that was not exactly ment for the printer that was being used).
Paul
