High viscosity fluid test services 1-15000 cps!!!
Can anyone put me in touch with a testing facility that is capable of measuring pressure drops of fluids flowing in a range of 0-100 gpm and viscosity range of 1-15000 cps? I have a product that needs to be put to the test. We want to know its full capabilities. Any help would be appreciated.
On the other hand, if anyone could reccommend a variable speed pump and flow metering system so that I may conduct my own testing, that would also be appreciated.
thanks.
thanks.
aspearin1
RE: High viscosity fluid test services 1-15000 cps!!!
http://www.zenithpumps.com/products/hseries.htm#Specifi...
Probably the better choice in your flow range
http://www.northern-pump.com/products.htm
