Pattern Split Lines?
I thought it would be possible to linear pattern a split line, but I guess not? If this is possible, what's the trick (SW03 SP3.1)?
I am trying to model diagnol red & white reflective conspicuity tape (C2), and I want the alternating bands to show in the part model. I thought I could use a split line to "slice-up" my part so I can apply colors to the alternating surfaces without having to insert a bunch of split lines (I just want to linear pattern it).
Are there some other suggestions on how to do this with using PW and decals?
Ray Reynolds
"There is no reason anyone would want a computer in their home."
Ken Olson, president, chairman and founder of Digital Equipment Corp., 1977
Have you read FAQ731-376 to make the best use of Eng-Tips Forums?
RE: Pattern Split Lines?
I thought you were onto something Tick, but I keep getting the error Split Line1: The sketch has more than one open contour.
I've managed to just insert the 9 required split lines to make this part. No big deal this time around, but I wouldn't want to do more than this.
Ray Reynolds
You can have a single contour that crosses over the face several times.
Extend the patterned sketch lines past the edges of the face, and connect the ends.
You might even make a small sawtooth-like contour and pattern that so they all connect into a single contour.
Ray Reynolds
Be naughty - save Santa a trip.
Thank you
Rashmin
Timelord
Having said that, here is what I do whenever I want to define a whole bunch of stuff to drive separate features from one sketch (including multiple split lines - hey, I have to do it too). I make the one sketch. I highlite everything EXCEPT what is required for the first feature and turn them into construction goemetry. I "Show" the sketch. Then in each subsequent feature's sketch I just do a quick convert entity on those bits of construction geometry I need. It is really pretty quick and everything is still driven from the one sketch. It is also easier to edit the individual features without having to re-compute the whole thing in one go (think about the cross checking required in a general case of your multi-split line!!). Plus you only have to figure out one failure at a time if there is a problem. You could also make the first sketch entirely construction and go from there - just hide it after you're done. To be honest that is probably cleaner and I sometimes do it that way.
