MASS PROPERTIES
MASS PROPERTIES
I am having a problem with mass properties regarding 'SURFACE AREAS' Each time I select the model (originally thinking I was sellecting a face only), I get the surface area of the 3-dimensional model which I now find is correct. But I don't want the surface area of the model, I want the surface area of a 'FACE' only.
Am I right in thinking that it is not possible to do this.
The only way I have been able to get arround this is to reduce the extrude to zero (0.0001) and divide the Surface Area figure generated by mass proprties by 2.
The application is a face with many different shaped holes. I need to take one from the other.
In this application it is not too much of a pain but I can think of another application ie a complex impeller were it would be a real pain.
RE: MASS PROPERTIES
RE: MASS PROPERTIES
