Fabrication of mixer blade supports to facilitate satic balancing
We have large mixer blades that have to be repaired from time to time
and as such we need to have these blades balanced to eliminate whipping of
the rotor. The speed of the blade is 48.2 rpm and the weight of the blade is
8555 lb. Does anyone have suggestions as to a company in the staes that fabricates mixer blade supports to facilitate static balancing.
RE: Fabrication of mixer blade supports to facilitate satic balancing
It doesn't take much to static balance the blades yourself.
Good luck
Ralph
