Waterproof Wire Penetration Fitting
Please give me references for manufacturers of any waterproof wire penetration fittings/systems.
Wire penetration must withstand up to 300 feet of water head, (130 psi) maximum.
Wall thickness of bulkhead is from 1/4" up to 1/2".
Wire size is AWG #3 through AWG #10.
Large volume of these will be purchased on a continuous basis.
Google no worky with every keyword I could think of.
Thank you for any help.
PUMPDESIGNER
RE: Waterproof Wire Penetration Fitting
Now I am on the track.
PUMPDESIGNER
http://www.thomasregister.com
and type Bushings: Electric Conduit, Outlet under Product or Service, which will return 26 companies to approach to
PUMPDESIGNER
