Effects of heat on a motors life
I'm trying to find some information on the effects of heat on a motors longevity. I want to say that someone told me once that for every 10% you lower the motor temperature you can extend the life of the motor by about 10 years. Has anyone else heard that before or am I totally off base here.
RE: Effects of heat on a motors life
http://www.ecmweb.com/ar/electric_hot_issue_motor/
"As a general rule of thumb, insulation life doubles for each 10° of unused insulation temperature capability. For example, if you design a motor to have a total temperature of 110°C (including ambient, rise, and hot spot allowance), but build it with a Class B (130°C) system, an unused capacity of 20°C exists. This extra margin raises the expected motor insulation life from 20,000 hr to 80,000 hr."
"Similarly, if a motor's load is less than full capacity, its temperature rise will be lower. This automatically lowers the hot spot temperature and extends motor life. If the motor operates in a lower than 40°C ambient temperature, its life will be longer. The degree rule applies to motors operating at {sic: or} above rated temperature; insulation life drops by half for each 10°C of overtemperature."
j[code}Ωÿ
http://www.silicavalley.com/archives/Reliability.pdf
for the mathematical relationships often referred to Arhenius relations, curves, aging, etc.
