?about nonrectangular viewports and ones from OBJECTS??
Ive noticed something when you go to lock the display of a viewport and the viewport was or is created from a pline the pline is still there but you can't actually get rid of the pline with out deleting th vport has anyone had this problem
also ontop of that if you had a plinewid of something and then converted that to a viewport then the vport has that plinewid as well kinda annoing don't you think
if everyone helps everybody the world will be a better place
