JLCC x PLCC IC packages
Dear friends,
I have an EPROM IC which package is JLCC (J-lead chip carrier), but my EPROM programmer only accepts PLCC (plastic lead chip carrier) sockets. I do not know if there is compatibility between these standards and I am afraid to damage the IC. So I ask: what is the main difference between a JLCC IC package and a PLCC one?
RE: JLCC x PLCC IC packages
( search for programming adapters )
The pin-out may be the same or different -- get the data sheet and compare them.
<nbucska@pcperipherals.com>
You can also go to JEDEC.org and get the standards (if you can identify them...).
Or, as nbucska says, get an adapter from www.emulation.com or elsewhere.
Mike
Mike Kirschner
Design Chain Associates, LLC
http://www.designchainassociates.com
