Different material for a multibody part
Ive have a multibody part . Is it possible to have different material for the solidbodies of that part ?
RE: Different material for a multibody part
Not that I know of, but I'm not the sharpest knive in the drawer. Wouldn't think you'd be able to have a Part (even if it is Multi-bodied) have more than one....
Mr. Pickles
Using PhotoWorks you can assign each surface a material.  Perhaps the same could be done with multibodies, only not with material density information keeping proper track.
Jeff Mowry
Industrial Designhaus, LLC
http://www.industrialdesignhaus.com
Having a need for different materials indicates that you should be using an assembly. The muiti-body function is not intended to be a substitue or alternative to an assembly. It is intended to simplify the geometric creation of a single piece part.
Parts from a mutibody part can be inserted into new parts of their own (right click in desing tree). The newly created parts can have their own material and drawing. You could even create the assembly you should have created in the first place.....
Be nice.......
GorBlimeyLimey hit the nail on the head.  A part is A PART not an assembly. It is a different type of file. Multi-bodies are indead just a modelling tool. I don't see and change occurring in this situation (and hope there never will be, still it would turn into a file translation nightmare for many of us).  The only possible LOGICAL use of different mass props in a single part file would be for composite type materials.  And that is a stretch - also highly complex if it were truely modelling composites.
If you really HAVE to use a multi body to design several PARTS (though heaven knows why - there are much better and standard ways), you could have a configuration for each "part" and suppress the others, then make an assembly.
If your "parts" have dependencies or are mirrored, etc. you can EDIT part (as opposed to OPEN part) in the context of the assembly, mirror parts, etc.  You can even get rid of the in-context relationships that may or may not result from this if you wish, though it sound like you want to keep them.
The software has a lot of tools for doing these types of things ( as with most similsr packages).  It is always best to use the methods they INTEND you to use.
Forgive me for assuming, but my trainer/application support engineer/VAR background is making me sense a self-taught user.  I recommend getting assistance from your VAR and/or a training class and/or read the manuals/help from cover to cover and look at all the features of the software, noting what they intended purpose is.
Be naughty - save Santa a trip.
