Flexible Piping Insulation?
I am involved with a new floating jetty instalation and need to transport various liquids at ambient temperature across from dock to the floating jetty.
My problem is how do I insulate (not heat trace) the flexible piping which links jetty to the dock.
Services include fresh water, diesel oil and sewage.
Does anyone know of a manufacturer for this type of insulation?
Thanks in advance
RE: Flexible Piping Insulation?
I would use armstrongs armaflex brand insulation. It is a soft closed cell insulation that has very good temperature range for cold products, but a limited hot temperature range of about 195F. Depending upon the temperature differential of the product to the environment, multiple layers may be needed. You will also need to install an UV protector, usually a mastic, depending upon the service(hot or cold). I will add that this type of insulation is very easy to install
Donkin
www.armacell.com/
Armstrong no longer makes it. It can be obtained at any refrigeration supply house.
I am not sure of your reason for the insulation and to where it will be applied? In the water?
Diesel oil and sewage may need to be double contained, better check with local codes.
Could you provide more information as it would satisfy my curious mind.
Good Luck
pennpoint
The jetty services shipping and the boats require fresh water, demin water and diesel. We also need to remove sewage to a treatment plant.
Fresh water flow is about 270 m3/hr (72,000gall/hr)the only reason for the flexibles is to take up the rise and fall of the jetty.
