Alternative Disposal method for Trichloroethylene
Good day,
I am seeking an alternative disposal method for spent trichlorethylene. We currently dispose of trichloroethylene at a hazardous waste site in South Africa.
Does anyone one know of any industries that may be able to use spent trichloroethylene in their processes?
Thanking you in advance
RE: Alternative Disposal method for Trichloroethylene
With the provisos above, TCE is a very effective degreasing solvent, without the flammability concern represented by non-chlorinated materials of similar solvent effectiveness. I'd recommend that you either send it to a solvent recycler for distillation/re-use, or you set yourselves up to do the same. The bottoms will still be chlorinated hazardous waste, which means big money for disposal- but the volume of waste will be greatly reduced. You'll have to run an economic analysis to see if it'll work out cheaper than what you're doing already, though.
Try Safetykleen, they produce a premium grade 150 solvent (petroleum naptha) that doesn't contain the chlorine. It also has a high flash point that reduces the fugitive voc's. Great for Clean Air Act VOC reductions. As a matter of fact, when we switched, our fugitive VOC emissions dropped by approx. 1 ton per year.
Hope this helps.
saxon
Visit www.eurochlor.org/chlorsolvents/issues/issues1_2_2.htm
it may be of help.
