Non-linear properties of bolt
Hai,
Do you know any source for getting non-linear (multi-linear elasto-plastic properties) properties for bolt material.
Bolt size - M8*1.25
Material-42cr4Mo2
Tensile strength - 700 to 1150Mpa
0.2% proof strength - 490 to 750
If there any web-sites or text books or any other source,please provide the same.
Logesh.E
Bolt size - M8*1.25
Material-42cr4Mo2
Logesh.E
RE: Non-linear properties of bolt
Are you concerned with temperature, high or low?
http://www.hexagon.de/dose/dose1e.htm
http://www.bossard.com/techinfo/en/index.html
