Yield Strength, Elastic Limit, Creep Effect
HI, How can I get the yield strength of A335 P22 at temperature of 955F? Is the following correct?
30000/20000x11000=16500
Where,
Yield strength at normal temp=30000psi
Allowable stress at normal temp by ASME B31.3=20000psi
Allowable stress at 950F by B31.3=11000psi
My problem is that the pipe expansion loop does not resume the original installation position when it cools down after
normal operation at 955F. Does the calculated stress has to be larger than the yield strength at the deformation points?
Many thanks
I hope to find a source for an accurate yield strength because the calculated thermal stress is pretty close to the yield strength I calculated using that formula.
I agree on your understanding about ASME codes, And in my situation, I think the original designer missed one support at the loop so that each time the pipe to expand, it takes the deformed position as the cold position and when it cools down again the pipe yield further more.
After years of operation, the deformation became significant till we have to take care of.
The value tabulated in ASME II D for SA-335 P22 yield strength at 955°F is 24.69 ksi: don't forget that this is a tabulated minimum, and that actual strength might be considerably higher.
You get a lower value from the allowable stress because at that temperature long term (creep) effects are accounted for in the allowable.
I don't understand the described behaviour: if your calculated stress is close to 16 ksi, then you shouldn't have any accumulation of plastic strain, that would start somewhere beyond the double of the yield strength. Of course creep also might come into effect, as you refer to years of operation.
Your explanation on the pipe not coming back could be a good one, however this still requires a somewhat higher stress and also that, on coming back, some permanent deformation would occur at a location outside your expansion loop.
prex
Prex,
It seems that the piping stress is much smaller than the yield strength and the piping deformation was supposed not to happen. And I'm sure that no stress can be higher than 18ksi arround the loop.
I'm interested in your words "creep effect" that may be the only cause for the deformation but how can I theorically explain the behavior when the stress is lower than the yield strength?
The piping loop is kind of special and if you could send me your email address, I will be very happy to send you the graphic picture...
Bulk
Creep is of course the accumulation of plastic deformation just because of sustained stress: only the time spent with high stress is of importance, not the cycling.
One of the criteria for determining the allowable stress in the creep range by ASME is that it may be equal to the stress that will cause 0.01% deformation in 1000 hr. If your pipe stays at high temperature for long periods, say 5000 hr per year, and the accumulated service is 10 year, this could (as a maximum) lead to an accumulated strain of 0.5%: don't expect this can fully explain your observations.
prex
MJCronin:
I strongly suggest that you re-post this question in the "Piping & fluid mechanics engineering" forum........people like "John Breen" and "cb4" could shed a lot of light on this question....
Also see:
Thread391-79795
Where,
Many thanks
prex
Prex,
Bulk
prex
MJCronin:
Also see:
Thread391-79795
RE: Yield Strength, Elastic Limit, Creep Effect
We also have a large vaporized heating fluid distribution system where all the piping was installed with “Cold Spring”. It worked too as all hangers are essentially vertical.
