finding a 50Ohm 13.56MHz antenna for RFID reader
I am trying to build an RF-ID reader into an existing demo kit. Trouble is, the antenna supplied (connected via 50Ohm co-ax cable) with the reader is too big to squeeze inside the demo-kit case.
I need to find a 50Ohm 13.56MHz pcb-antenna that is max 5cm x 10cm or preferably is flexible so it can be squeezed in. Any ideas where I can get one, or how I might improvise. I am not an expert in this field - we are a software company primarily!
RE: finding a 50Ohm 13.56MHz antenna for RFID reader
tuned to the output frequency and designed to be 50 Ohm
<nbucska@pcperipherals.com>
