Switching Industries
Hi folks,
I've been reading through some of these career-based posts and found lots of information to ponder. Now I've got a question of my own I'd like to pose.
I am currently working in the aerospace industry (3 years now) for a turbine overhaul and repair company. Originally, my job was to develop repairs for defective engine components. Over the last 1 to 1.5 years, my job has changed gears to processing jobs that come through the shop.
My big question of the day, is how hard is it to find a job in a different industry, doing different work? Example, my dream job (so I hope) would be working at an automotive company doing R+D on engines, as I enjoy heat transfer and thermo.
I graduated in 2001 with my BSME, and am about 1/2 through my MSME.
Any help, ideas, or thoughts would be greatly appreciated.
Thanks!
Thanks!
RE: Switching Industries
However, if your MSME has some focus on automotive then that should help.
It would also help if you can network and find an internal contact so that your resume actually gets looked at for more than 10 seconds as someone picks it off of the pile.
Try to identify the skills and experience from your current position which are directly applicable to your desired position and then play those up on your resume/cover letter.
My personal experience has been that it's tough to switch industries but not impossible.
Begin to form more direct connections to your target industry. In your case, get an SAE memberbership to start - the SAE covers both Aerospace, automotive, and other vehicles (www.sae.org). This will fit with both your current and target employment. This gives you one more connecting thread on your resume.
Also, keep your eyes open to less ovibous companies that may be involved with the technologies you would like to work on. Detroit is not the only one doing engine R&D. Industrial and marine companies are very involved also (Caterpillar, Cummins, Mercury Marine, etc.). Use your time till you finish your MSME to investigate and select the best companies and get to know them.
1) get into R&D on aerospace turbines
then
2) transfer across to R&D on automotive engines
This should not stop you from applying direct for automotive jobs in the interim, of course.
FWIW I work for one of the big 3 in Australia and we happily interview aerospace guys (so long as they'll do FMEAs OUR way, not their way). There again we still have a skills shortage out here.
Cheers
Greg Locock
