Engine cooling
Engine cooling
Hi
Is it really neccesary to cool the engine block? Isn't most of the heat in the head?
RE: Engine cooling
RE: Engine cooling
I have seen some water jackett filler products, can one fill half the block with that?
RE: Engine cooling
RE: Engine cooling
Heat transfer is a function of flow rate, flow geometry, and heat transfer coefficients. In the cylinder area, the apparently large voids may be required to provide enough coolant mass with lesser flow.
RE: Engine cooling
There are several purposes of filling the block. They are
1) To keep some heat in to improve thermal efficiency of the motor for a short time.
2) To improve the strengthy and avoid splitting the bores under very high stress.
3) To keep the bores round and straight so as to aid in ring seal
pat
RE: Engine cooling
On drag engines they fill the whole thing, since they don't run radiators, and billet heads, however on oval racing they fill them half way as far as I know... According to Hardblok you can fill a street engine 1/3.
RE: Engine cooling
In fact, the exhaust valve will be opened for tha bottom 1/4.
Alcohol runs a lot cooler in the inlet manifold, and somewhat cooler in the chamber. This equals somewhat lowwer cooling system requirements, but bigger heat difference between inlet charge and power stroke, which means more power.
pat
RE: Engine cooling
RE: Engine cooling
I suggest you read SAE Publication SP-1541 "A Systems Approach to Engine Cooling Design". That will tell you how the OEM's do it.
PJGD
RE: Engine cooling
One thing that it does for you, which I haven't seen mentioned, is that it increases the coolant velocities in the upper (remaining) part of the jacket, and improves cooling in that region.
RE: Engine cooling
RE: Engine cooling
I would fill it to 1/2 the stroke length down from the top of the deck, which is probably to about the water pump inlet holes on a SBC
pat
