Non-linear properties for bolt
Hai,
Do you know any source for getting non-linear (multi-linear elasto-plastic properties) properties for bolt material.
Bolt size - M8*1.25
Material-42cr4Mo2
Tensile strength - 700 to 1150Mpa
0.2% proof strength - 490 to 750
If there any web-sites or text books or any other source,please provide the same.
Logesh.E
Bolt size - M8*1.25
Material-42cr4Mo2
Logesh.E
RE: Non-linear properties for bolt
You should post this request in the Metal and Metallurgy engineering (forum-330). I know of at least one member of that forum that should be able to help you.
Best regards,
Matthew Ian Loew
"Luck is the residue of design."
Branch Rickey
