NPT & BSP pressure rating
I'm having difficulty locating reference information for maximum operating pressure for NPT and BSP threads up to and including 2". Thanks for any help.
NPT & BSP pressure ratingNPT & BSP pressure rating(OP)
Red Flag SubmittedThank you for helping keep Eng-Tips Forums free from inappropriate posts. Reply To This ThreadPosting in the Eng-Tips forums is a member-only feature.Click Here to join Eng-Tips and talk with other members! |
ResourcesWhat is rapid injection molding? For engineers working with tight product design timelines, rapid injection molding can be a critical tool for prototyping and testing functional models. Download Now
The world has changed considerably since the 1980s, when CAD first started displacing drafting tables. Download Now
Prototyping has always been a critical part of product development. Download Now
As the cloud is increasingly adopted for product development, questions remain as to just how cloud software tools compare to on-premise solutions. Download Now
RE: NPT & BSP pressure rating
API 6A -- refers to "line pipe" thread rather than NPT. The now-retracted 18th edition had a note on interchangeability for sizes up to 1 1/2" with a caution that the slight variation in thread form can increase wear and tendency for galling after several make-ups.
Table 4.1 in the 17th edition summarizes the pressure limits, but one needs to keep in mind the material requirements in Table 5.2 (which exceed those of ASME valves, for example).
ASME B31.1 and B31.3 are both piping specs (power and process respectively), and short of detailed stress analysis, neither standard addresses pressure ratings for female threaded connections. B31.3 does mention (para 314.2.1c) that "female threaded components shall be at least equivalent in strength and toughness to threaded components listed in Table 326.1", which in turn references numerous other standards including B16.34a for valves.
