12volt motor speed controller
I have a 12v automotive starter I am using for a drive motor on a kart but have no way of controlling it yet. it pulls an initial load of 250amps and decreases to aprox 100amps after a couple seconds. i'm using a 70a/h SLA battery. what I need is a controller that doesn't have all the extras on it(braking,reverse.etc). something simple that will decrease amperage so my batteries will last longer and hopefully increase motor life. most controllers I have found so far are listed as 24-48volts very few are listed 12v. similar to golf karts. is it possible that I use a controller to drop amperage to 60-70 amps without damaging the motor? or does the controller control voltage?
RE: 12volt motor speed controller
it is equivalent with .50* 12V = 6V )
<nbucska@pcperipherals.com>
http://www.processregister.com/Curtis%20Instruments%20I...
Barry1961
http://www.thomasregister.com
and type Controls: Electric Motor, DC under Product or Service, which will return 20 companies to approach to
and type Motors: Golf Cart under Product or Service, which will return 2 companies to approach to
