Send Linetype to Layer
Dear Folks;
In autocad 2002 What would be the quickest way to make all hidden lines go on to their own layer ?
I know you can select the hidden lines and use match properties to bring them on to the desired layer, but I need something a little less time consuming.
Best Regards
Adrian D
Best Regards
Adrian D
RE: Send Linetype to Layer
You can use "quickselect". Search for linetype-> hidden-> if all hidden objects are selected, You can cange the layer
Lothar
