Hidden Line Scale
Hidden Line Scale
Dear Folks;
Is there a way to adjust the line type scale for hidden lines in solidworks 2004? The hidden lines in my 1:1 views are much too small.
Best Regards
Adrian Dunevein
aaadrafting.com
Best Regards
Adrian Dunevein
aaadrafting.com
RE: Hidden Line Scale
Scott Baugh, CSWP
http://www.3dvisiontech.com
http://www.scottjbaugh.com
FAQ731-376
any way, if u want to change the scale of those hidden lines, first finish dimensions and other title block details. then save as drg file format.
open this drawing in autocad. here u can change the scale of hidden lines easily.
for this use ltscale command in autocad.
this way only i'm doing for my components.
any comments? any other ways?
thanks,
regards,
Murugan. S
Design Engineer,
GlobalSoft Pvt Ltd,
New Delhi - INDIA
murugan_subham@yahoo.com
These drawings are being converted to .dwg format and I am using ltscale, but I will submit an enhancement request because I would prefer to keep everything in solidworks drawing format as much as possible.
Copying to autocad only creates more work later due to conversion errors, tons of dimstyles and mismatched fonts. I dont want to be fixing up the acad files, that in itself opens up the possibility for more errors.
Again many thanks
Adrian Dunevein
Some time ago I asked about this, in SW2001+ the line types are based on ACAD ver 13, these can be found in the following file 'swlines.lin' located here:
Program Files\SolidWorks\lang\english\
I never got around to having a play, decided to just live with it. But you might want to have a go altering some of the variables. As always I would recomend backing up this file before you play. Not sure if this will work or not.
Have fun
Dave
I played with the file you suggested & it works a treat.
I have copied the contents of "swlines.lin" below. The positive number is line length & negative number is space "length".
These cannot be changed on the fly though, SW has to be restarted before changes take effect. Hopefully SW will create a bigger variety of selectable lines in future versions.
;; Based on AutoCAD Ver. 13.0's Line Styles Format
;; A length/space of '1.0' is equivalent to .2 inches.
*CONTINUOUS,Solid
A,12
*HIDDEN,Dashed
A,.25,-.125
*PHANTOM,Phantom
A,1.25,-.25,.25,-.25,.25,-.25
*CHAIN,Chain
*CENTER,Center
A,3,-.25,.25,-.25
*STITCH,Stitch
A,0,-.125
*CHAIN_THICK,Thin/Thick Chain
B,THICKENDS
*CONTINUOUS,Solid
A,12
*HIDDEN,Dashedx4
A,1.0,-.5
*HIDDEN,Dashedx3
A,.75,-.375
*HIDDEN,Dashedx2
A,.5,-.25
*HIDDEN,Dashed
A,.25,-.125
*PHANTOM,Phantom
*CHAIN,Chain
*CENTER,Center
A,3,-.25,.25,-.25
*STITCH,Stitch
A,0,-.125
B,THICKENDS
Ray Reynolds
"There is no reason anyone would want a computer in their home."
Ken Olson, president, chairman and founder of Digital Equipment Corp., 1977
Have you read FAQ731-376 to make the best use of Eng-Tips Forums?
thanks
djw2k3 and CorBlimeyLimey .
regards,
Murugan. S
Design Engineer,
GlobalSoft Pvt Ltd,
New Delhi - INDIA
This is good information to know. Either djw2k3 or CorBlimeyLimey should make the FAQ.
If neither of you do let me know.
Scott Baugh, CSWP
FAQ731-376
Yes, I did. Please check out FAQ559-863.
Many thanks and pats on the back to everyone who helped with this little problem. Please send in your suggestions to solidworks too !
Now I know I'm giving myself scaled hidden lines for christmas !
Many many thanks
Adrian Dunevein
aaadrafting.com
