SMADA 6.46
SMADA 6.46
Having some problems with this program and have been unable to get answers from the program authors, so far.
Are there any users of the program SMADA on this forum who might be able to help?
I'm trying to create a unit hydrograph in the program and then route it through a detention pond. No luck at all to date.
In case you're not familiar with the program, here's a brief description:
The SMADA programs were written to accompany the textbook
Hydrology: Water Quantity and Quality Control 2nd Edition by
M.P. Wanielista, R. Kersten, and R. Eaglin. The text is
available from John Wiley and Sons publishers.
http://www.wiley.com/
RE: SMADA 6.46
RE: SMADA 6.46
Thanks for your reply. I have contacted Prof. Wanielista who says he thinks there may be bugs in some parts of the program but they can't be fixed immediately since he's busy with other things.
If you don't mind, please tell us what you use now instead ?
HEC-HMS, or WMS or something else ?
Russ Faust
RE: SMADA 6.46
I used to use SMADA and it is a good program. However I now use Hyrdrographs by Intelisolve. It is very user friendly and you can run several storms at once. Also it is inexpensive - under 300. Let me know if you have any questions i can help answer.
