Fuel consumption per hour for CAT diesel generators
Hello all,
I need information on the fuel consumption per hour for CAT diesel sets with the following ratings: 320kVA, 500kVA, 590kVA, 725kVA, 800kVA and 1000kVA. Any other information on their operating characteristics will be appreciated.
Thanks.
Thanks.
RE: Fuel consumption per hour for CAT diesel generators
http://www.cat.com/products/engines_n_power_systems/spe...
for the standard kVA genset size of 350kVA
Then, use wizard
http://vidswizard.catmms.com/catwizards/vidswizard/jsp/...
to obtain 100% load with fan consumption 26.1 gal/hr
Similarly for the other (maybe approximate) sizes.
In order to find fuel consumption you will need to supply the KW ratings of the engines you need. You should be able to visit the Cat website, this can direct you to your local Cat dealer that should be happy to answer your questions.
///The Cat website vizard provides this information.\\\
