Latest Etabs version
Does anybody knows what is the latest version of Etabs and when was released?
RE: Latest Etabs version
Amadeus
I would be obliged if you can send me also the changes for SAP2000 v8 (8.08 up to the last).
Thank you.
- Reissued on CD.
- Support for other languages has been added.
- The Chinese Building code implementation has been updated.
- Support for Frameworks Plus V7.1/7.2 has been added.
- Section Designer has been updated.
- Other minor bug fixes.
Changes from V8.3.7 to V8.3.8 (10/21/2003)
- This is the first release of ETABS with the Chinese Building Codes.
The activation of these codes requires special licenses. These
licenses are only available when purchased through the Chinese Dealer.
Changes from V8.3.5 to V8.3.7/2 (10/24/2003)
- Beam partial fixity springs are now accounted for in K-factor
calculations.
Changes from V8.3.0 to V8.3.5 (09/04/2003)
- Additional eccentricities (accidental torsion) can now be specified
for Response Spectrum cases. The program will automatically add a static
load case with the additional moments caused by the diaphragm dynamic
loads and the specified eccentricity. The results for the Response
Spectrum case will automatically include the response from this added
static load case.
- Design Forces are now viewable in database tables
- Time History Forces are now available in database tables on
a step by step basis as well as envelopes
Changes from V8.3.0 to V8.3.0/2 (08/12/2003)
- Reissued with minor changes to working of the license.
- Wall Design time reduced.
- Minor changes to Composite Beam Design. More beams should now
be able to be designed.
Changes from V8.2.7 to V8.3.0 (07/29/2003)
Changes from V8.2.6 to V8.2.7 (06/13/2003)
- Reissued as full installation on CD.
- Examples updated.
- Verification Manual added.
- Explicit meshing options added to Section Designer for property calculations.
Changes from V8.2.4 to V8.2.6 (05/06/2003)
- Explicit menu command to add default design combination added.
- Program version now determined from available license.
Changes from V8.2.3 to V8.2.4 (04/18/2003)
- Manuals updated.
Changes from V8.1.5 to V8.2.3 (04/08/2003)
- The program now supports LPM/6 for CIS/2 Step file import
and export.
- The program now supports Import from Frameworks Plus.
- The program now supports Export in SDNF format.
On the last change is written "Support for other languages has been added". This mean that the menus could be in different languages?
