DRAWINGS- DIMS DON'T COME FROM MODEL
SW04
WHEN I CREAT A 3VIEW DWG FROM A MODEL I DO NOT GET DIMENTIONS TRANS FERED OF DISPLAYED HOW DO I FIX THIS. IT HAPPENED AFTER UP TO 04. I CAN MANUALLY ADD WITH DIMENTION TOOL BUT THIS IS SLOW.
THANKS FOR HELP
THANKS FOR HELP
RE: DRAWINGS- DIMS DON'T COME FROM MODEL
Could you provide some details about your environment, OS, hardware, graphics card, processor, etc.
Go to Tools, Options, Document properties, detailing.
Under 'Auto Insert on view creation' select 'Dimensions marked for drawing.
If this works save it in your drawing template file.
Roller1
Otherwise Roller1 is correct for auto insert of Dims. but you still have to have the dims in your part "marked for drawing" checked.
Scott Baugh, CSWP
http://www.3dvisiontech.com
http://www.scottjbaugh.com
FAQ731-376
