Continuous binary distillation ethanol/water
Would appreciate suggestion of stripper section design for ethanol/water/solids. Height is limiting, diameter is variable.
Input 125,000 lbs/hour 8.38lb/gal beer.
Output Corn solids>20mesh grind, 15,000 lbs/hr.
Ethanol, 14,000 lbs/hr.
Water, 96,000 lbs/hr.
RE: Continuous binary distillation ethanol/water
how should i design an azeotropic column having a ternary mixture of benzene ,ethanol and water ?
