CAE-Using nodes/points on surface for features
In my vertebral model, I would like to apply different loading configurations to the top surface, which is complex and consisting of several rectangular patches.
My current approach is to use a centered reference point above the top surface, and attach it to various points along the top using beam connectors (I think that's the connector that I want, one that will transmit moments and loads directly to the surface?).
By default I can only use my reference point, and the vertices of the patches. That's rather limiting, is there a way to use nodes, or draw more points on the complex surfaces that I can use to attach beams to?
A rough sketch (i'd like to use point x, rather than the points o)
o------o--------o
| x | |
o------o--------o
o------o--------o
| x | |
o------o--------o
RE: CAE-Using nodes/points on surface for features
If you're using /CAE then go into the interaction module and select the coupling constraint. Then, select the surface that you want to apply the load through, then pick an assembly reference node in space. Now, all of your loads and moments may be applied through this node and will be transmitted to your surface without overconstraining it.
Good luck and best regards,
KF9RI
